alexjones95
Oct 17, 2023Aspirant
RBR20 + RBS20 Differing Speeds
So I’ve had an RBR20 mesh system with RBS20 satelite for many years. I’ve recently had a new router through Virgin for the 1GBPS Volt service. Since having this, the RBR20 router is producing rubbish ...
Oct 18, 2023Guru - Experienced User
What "rubbish" speeds are you getting?
You'll never see anything near 900Mpbs over 5Ghz AX on the Orbi system. Depending on your wireless clients, they may top out at around 300-500Mpbs on the down. Ethernet connected PCs should see near 900mpbs thru the RBR.
- alexjones95Oct 19, 2023AspirantHi. I’m talking sub 50mbps - really bad speeds. Whereas I get around 500mbps upstairs connected to the satelite?
