RTTorres
Mar 28, 2020Aspirant
RBR20 / RBS20 Very Unstable - Interrupted connectivity
HI. I have a RBR20/RBS20 setup in my house. For about three months it worked fine for the most part. Problem started in the past couple of weeks. WIFI drops several times a day, not a clear pattern. ...
Mar 29, 2020Guru - Experienced User
- RTTorresApr 03, 2020Aspirant
Thanks for your response. I did several factory resets and adjusted settings as suggested. Unfortunatelly no luck. I gave up and upgraded to RBK50 router and satellite, returning the RBK20 while I still can.
- FURRYe38Apr 03, 2020Guru - Experienced User
Sounds like the 20 series may have been faulty.
Enjoy the 50 series.
