maortiz1969
Jun 15, 2020Tutor
RBR20 & RBS20 x2 Giving very poor WiFi performance
I am completely frustrated with this system. I've owned it for about two years now and had no complaints other than the fact that I cannot designate which Satellite my stationary devices should conn...
- Jun 22, 2020
What are the speed results with a wired PC or laptop connected behind the RBR?Has a factory reset and setup from scratch been performed since last FW update?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Jun 22, 2020Guru - Experienced User
maortiz1969
Jun 23, 2020Tutor
We're onto something! Getting better throughput now. Doing some testing and tweeking and I will get back to you.
