maortiz1969
Jun 15, 2020Tutor
RBR20 & RBS20 x2 Giving very poor WiFi performance
I am completely frustrated with this system. I've owned it for about two years now and had no complaints other than the fact that I cannot designate which Satellite my stationary devices should conn...
- Jun 22, 2020
What are the speed results with a wired PC or laptop connected behind the RBR?Has a factory reset and setup from scratch been performed since last FW update?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Jun 25, 2020Guru - Experienced User
Wired connection thru the Orbi with a PC should see near 900Mpbs. Wireless will be depended upon your wireless devices and what they support, desiged for and what they connect with the RBR.
Even with a AC 5Ghz supporting link rate at 866Mpbs, this is a link rate only, not a thruput speed so wireless devices may max out at around 400-500Mbps on the down while others may max out at lower rates. I have a Galaxy Tab S2 that mostly maxes out at around 200Mbps. Usually see around 150Mpbs on average. Just what the pad was designed for and rated at when it was built.
maortiz1969
Jun 25, 2020Tutor
Ok, I understand now. Thank you soooo much for your help, patience and explanation! I am very happy with the resolution!
- FURRYe38Jun 25, 2020Guru - Experienced User
Enjoy. :smileywink:
