migstermav
Feb 18, 2020Aspirant
RBR20 1 of 3 Nest cameras wont show or record video after power cut
Hi, I have an RBR20 with 2 satellites. I have 3 nest cameras. After initial set up, they all worked fine, this conitinued for about 4 months. I had to cut power for electrical work, since the power c...
tomschmidt
Feb 18, 2020Virtuoso
Possibly the camera is faulty. To help verify this, swap its location with one of your working cameras to determine if it is a location WiFi issue, or if the problem follows the camera.
- migstermavFeb 18, 2020AspirantUnfortunately the cable is run through the outside wall which means I will need to open up a hole again to feed plug through, I was trying to avoid but I may have no choice. Thanks
