migstermav
Feb 18, 2020Aspirant
RBR20 1 of 3 Nest cameras wont show or record video after power cut
Hi, I have an RBR20 with 2 satellites. I have 3 nest cameras. After initial set up, they all worked fine, this conitinued for about 4 months. I had to cut power for electrical work, since the power c...
nicholb
Feb 19, 2020Luminary
Can you try connecting the camera to a WiFi hotspot from your phone? If so that would help you determine if the problem is in the camera or the Orbi.
Feb 19, 2020Guru - Experienced User
Since the user has the same model cameras and they connect to the Orbi fine, I presume that the one camera in question would be the problem and not the Orbi. However good idea to try a different wifi signal though.
