KWAZ2484
Nov 05, 2019Aspirant
RBR20 2.3.5.26 Homekit not responding
Hi Everyone, Per the title you can kind of see ehat my problems are. I currently have 2 Apple TVs set up and I can get them to connect to the Homekit network, but whenever I try to set them to do...
ekhalil
Nov 05, 2019Master
I think this is an iOS issue that has been around for some time now. Have you done enough troubleshooting to locate where the problem is?
But first, are you sure that your Apple TV, is connected to a hub? Please go to Settings > Accounts > iCloud and make sure that your Apple TV shows HomeKit as Connected.
KWAZ2484
I checked both Apple TV's say they are connected to "My Home". So maybe they are actually connected and able to work, but I'm just a moron and can't figure out the correct automation to be able to have them automatically turn on.
- ekhalilNov 05, 2019Master
ok, so now if you use the Home app on your iPhone and long press on the Apple TV, do you get the play window?
What happens if you try to pause/play on the control panel?
