Vulcan195
Dec 29, 2021Tutor
RBR20 accessing spam website?
So my setup is double NATd with ATT Fiber Modem being the top level firewall. I get this alert from the ATT modem. See pic. Attempt to access techsales.live Any clues?
Dec 29, 2021Guru - Experienced User
I'd be betting it on coming from one of the devices connected to the orbi.
CrimpOn
This is exactly correct. The AT&T router sees everything as coming from the RBR20 Orbi router. Because of Network Address Translation (NAT), the AT&T router has no way to distinguish individual devices behind the Orbi. Strange that this particular web site would be singled out as being a Spam risk. It looks like SO many others.
- Vulcan195Dec 30, 2021TutorThanks.
This is the first time the ATT firewall flagged traffic on RBR20. On the RBR20 network, I have a Firewalla device which does it’s own checks. I have to look into it. Thanks- plemansDec 30, 2021Guru - Experienced User
Sounds like you have more than 1 device inspecting your traffic. They probably use different algorithms or even inspection lists to compare to. Its why one might give a warning and not the other.
