tim-c
Mar 25, 2020Aspirant
RBR20 and a satellite, won't connect to amazon or any other internet other than Netflix.
I'm just having issues connecting to Amazon and everything else. Everything has been set up and Netflix works but nothing else. Any thoughts or help would be appreciated. Tim
CrimpOn
Mar 25, 2020Guru - Experienced User
tim-c wrote:I'm just having issues connecting to Amazon and everything else. Everything has been set up and Netflix works but nothing else.
What device is attached to the Orbi network and cannot reach anything besides Netflix?
- tim-cMar 26, 2020Aspirant
My smart T.V.
Thank you,
Tim
- plemansMar 27, 2020Guru - Experienced User
The actiontec is a modme/router combo device. do you have it in passthrough/modem only mode or the netgear in AP mode? otherwise you're in a double nat.
- Retired_MemberMar 27, 2020
plemans wrote:The actiontec is a modme/router combo device. do you have it in passthrough/modem only mode or the netgear in AP mode? otherwise you're in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
this qualifies as another..."how long have you had your Orbi?".....did you know you were going to have 2 routers??????
