tim-c
Mar 25, 2020Aspirant
RBR20 and a satellite, won't connect to amazon or any other internet other than Netflix.
I'm just having issues connecting to Amazon and everything else. Everything has been set up and Netflix works but nothing else. Any thoughts or help would be appreciated. Tim
Mar 27, 2020Guru - Experienced User
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
