ngockhoa0524
Aug 23, 2020Initiate
RBR20 and JuiceBox charger for EV
I have an RBR20 main unit + 1 Satellite for the last year or so and it's been working great ... until about a month ago when we installed the JuiceBox 40amp charger: after confirming with JuiceBox s...
Aug 23, 2020Guru - Experienced User
The RBR20 is dual band and it bandsteers. Meaning you have both bands and it'll move devices between 2.4ghz and 5ghz as needed. It doesn't have an option to fully turn off the wifi radio.
Unfortunately most app and IOT devices don't get coded properly. Meaning if you're phone is on 5ghz, many times you can't setup the 2.4ghz device.
try this.
1. turn the ssid broadcast (doesn't shut off the band, just the broadcast ssid) for the 5ghz.
2. disable wifi on your phone doing the setup.
3. turn wifi back on your phone. it should reconnect. hopefully it connects to the 2.4ghz.
if it does, try redoing the setup. Once its setup, turn the ssid broadcast back on.
If it doesn't, you can turn the broadcast power on the 5ghz down and then retry the same setup.
try these steps.
- ngockhoa0524Aug 23, 2020Initiate
Thanks so much for your suggestion #plemans.
Will try following your advice and will report back.
David
