TC67
Jan 02, 2019Follower
RBR20 and Spark fibre connection
I used the Orbi app to set up with my Spark fibre and all was ok, until I noticed that I couldn't access common websites (they gave me a error 404). I unplugged the Orbi and all was ok, but I was bac...
ekhalil
Jan 03, 2019Master
If when you unplugged the Orbi you network continued to work then that means that you had two routers in your network when Orbi was working. That is probably the reason for the issues you're seeing!
Please choose to either set the Spark router into bridged mode or otherwise set Orbi in AP mode.
You should -normally- have only one router in your network.
