djenkins040
Jul 27, 2021Aspirant
RBR20 and third satellite
RBR20 - Add a third satelitte and all satelittes disconnect after a few minutesm turning magenta. Router Version v2.7.3.22 (running patch for network drops) Satelitte Version v2.6.2.104 Add...
Jul 27, 2021Guru - Experienced User
Your RBS should be running same version of FW as the RBR...
- djenkins040Aug 02, 2021Aspirant
Code version the same across all the satelittes . When making changes to DHCP reservations, brikes all the sattelittes. Have to do hard rest of the router.
Thoughts,
- FURRYe38Aug 02, 2021Guru - Experienced User
What happens if you turn OFF the RBS then make DHCP reservations, apply the changes and wait for the RBR to reboot, then turn ON the RBS?
Are you setting up DHCP reservations for the RBS?
Has a factory reset and setup from scratch been performed since last update?
- djenkins040Aug 03, 2021Aspirant
Have not tried to turning off the RBS and then making changes. Understand the reason behind your comment, but overall that "should" not be a standard process for changing configuration, config happens on RBR.
Not doing reservations on RBS, all config done on RBR.
Factory reset has not been done. If the issue is coruption then it would be a PIA to redo the configuration. Not impossible, just time consuming for the reservations, which are about 25.
Thanks
