jumpinomega
May 04, 2020Aspirant
RBR20 Assinging 169 ip addess to my sony tv.
Please help. I have an Orbi that is; Assigning a 169. ip address to my sony tv that is 2 years old. This is a random occurance that will last for multiple days and then return to a valid ip address...
- May 04, 2020
jumpinomega wrote:I still worry about the multiple SSID networks that are showing for the one SSID network. ...An issue for another day.
Two I can understand (2.4G and 5G). More than two is harder to explain.
May 04, 2020Guru - Experienced User
Be sure to set a custom SSID name to your RBR wifi. So you know what SSID name to connect to for all of your wifi devices.
Do other devices get connected to Orbi sucessfully?
jumpinomega wrote:Please help. I have an Orbi that is;
- Assigning a 169. ip address to my sony tv that is 2 years old. This is a random occurance that will last for multiple days and then return to a valid ip address.
- 2 or 3 Orbi networks available for use (I only have 1 orbi with No added satalites)
I would really like to get this issue resolved.
I do have a sound bar that is wired to the tv. I have unplugged the sound bar from the tv for multiple days, to see if the sound bar was causing an interference, but this has proven to not resolve the strange ip address.
I have tried to assign a static ip address as well with no luck.
I have gone to the netgear website and checked the advanced setting to make sure that the tv is not blocked.
Any help would be wonderful.
- jumpinomegaMay 04, 2020Aspirant
- V2.3.5.30
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- Spectrum, Modem Model # E31T2V1
- I will do this today.
- There are certain devices: my sons tablet, Google Hub, and one of our Nintendo Switches.
- I frequently loose wifi to all devices. This is random. I can have 2 devices running or 16 devices running. Sometimes we can go a whole week without loosing connection and then some days we loose connection repeatedly.
- I have rebooted the Orbi a few times. But I do not like doing this because it can take upto 24 hours before the Orbi connects all devices again.
- I have 200 mbps from Spectrum.
- FURRYe38May 04, 2020Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
jumpinomega wrote:What Firmware version is currently loaded?
- V2.3.5.30
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).- jumpinomegaMay 04, 2020Aspirant
- I am only running the main orbi. I do not have the satalite hooked up because the orbi would not recognise it....? Another issue.
- My orbi router is only a few inches from the modem.
- I live in a 1200 sq ft home. All devices seem to receive a good signal from any area of the home.
- Which channel would be best? Or does it matter?
- We have 5 neighbors with wifi at the moment.
- Enabled Beamforming and MIMO
- WMM already enabled
