jumpinomega
May 04, 2020Aspirant
RBR20 Assinging 169 ip addess to my sony tv.
Please help. I have an Orbi that is; Assigning a 169. ip address to my sony tv that is 2 years old. This is a random occurance that will last for multiple days and then return to a valid ip address...
- May 04, 2020
jumpinomega wrote:I still worry about the multiple SSID networks that are showing for the one SSID network. ...An issue for another day.
Two I can understand (2.4G and 5G). More than two is harder to explain.
jumpinomega
Can you please explain "2 or 3 Orbi....". Are we talking about the Sony connecting to 1 Orbi, or ???
- When I "forget my wireless network" and then look for my wifi network, I will see 2 or 3 Orbi networks available. I can click on each one of them, enter my password on all three and they all accept the password.
How was the "static IP" assigned to the Sony TV?
- Using the Sony network setup to define the IP as "static" and also enter the Gateway and DNS IP addresses? or This is the way that I did it.
- Creating an IP assignment on the Orbi web interface, Advanced Tab, Setup, LAN Setup?
If the Sony is configured with a static IP (on the Sony), then it is critical that no other device on the network get that IP address by accident. That would create an "ARP conflict" where two devices claim ownership of the same IP address, and the Sony might decide "oh, s**t, I can't use the IP I want to."
- I made sure to assign a unique ip address to the Sony tv. I checked the ip addresses of all other devices to make sure that I did not duplicate.
So, how the Sony is set up and how the Orbi DHCP/LAN assignments are configured may hold the key to this mystery.
- How so? I would love to get this figured out so that my family and I can stop getting cut off from the world.
CrimpOn
May 04, 2020Guru - Experienced User
jumpinomega wrote:Can you please explain "2 or 3 Orbi....". Are we talking about the Sony connecting to 1 Orbi, or ???
- When I "forget my wireless network" and then look for my wifi network, I will see 2 or 3 Orbi networks available. I can click on each one of them, enter my password on all three and they all accept the password. This is fascinating. Does every WiFi device you have do this or only some of them?
On the Orbi web interface, Advanced Tab, Setup, LAN setup there is a section for "Use Router as DHCP Server". Is the IP address that the Sony is using in the range of addresses shown in the boxes for Starting and Ending IP address. It should NOT be.
I neglected to ask which model Sony TV this is. Would like to search for that model and Auto IP assignment problems. My Sony TV is about 1 year old and it just started popping up a notice about new firmware.
- jumpinomegaMay 04, 2020Aspirant
- No, just the Sony TV
- It is in the range of the 2 ip addresses. All of my other devices are within those two ranges as well.
- Model # XBR-65X850F
- CrimpOnMay 04, 2020Guru - Experienced User
The Sony TV should not have a static IP address that is in the range of IP's that the Orbi will hand out to device which ask for one.
Can you move it outside the range?
If the range now goes from 1 to 254, just make it from 1 to 200 and set the TV to 201.
(or 1 to anything and set the TV to one higher.)
My tv has wifi again. The orbi has assigned an ip and all is right in the world again. My husband will be happy.
Now I just need to make sure that it doesn't keep happening.
To clarify, if I set a manual static ip address, I need to make sure that the ip address is outside of the range of the ip addresses used by the orbi, correct?
