Mahers
May 28, 2020Aspirant
RBR20 Blocked all access to router settings
I've had the Orbi RBR20 and one satellite for a while and really like it. Today, I added a new device to my network and accessed the settings to rename it. While in there, I wanted to turn on Access C...
Mahers
CrimpOn Sorry. That sentence is in reference to using the mobile app on my phone. I have to disconnect my phone from wifi in order for the app to let me in. But even in the mobile app, I cant't turn off the "Block all new devices" setting. I can only pause internet access to each device. All of my devices are on, and connected and working fine, but I can't log into the router settings from any device to turn that setting off. (No idea why it's even an option. Every time I try to use it, it seems to mess things up.)
CrimpOn
May 28, 2020Guru - Experienced User
Mahers wrote:CrimpOn Sorry. That sentence is in reference to using the mobile app on my phone. I have to disconnect my phone from wifi in order for the app to let me in. But even in the mobile app, I cant't turn off the "Block all new devices" setting. I can only pause internet access to each device. All of my devices are on, and connected and working fine, but I can't log into the router settings from any device to turn that setting off. (No idea why it's even an option. Every time I try to use it, it seems to mess things up.)
Thanks for the explanation. (I should have figured that out myself.)
This is really strange. On the laptop, for example, which is "working", when you browse to the Orbi web interface (http://orbilogin.net), and authenticate ("admin" and password), does it let you do anything? (Display Attached Devices? Look at the Guest Network page?)
- MahersMay 28, 2020Aspirant
CrimpOn I can't even get to the login page. If I go to the www.orbilogin.com or ip address, the message immediately appears. I just unplugged the router and plugged it back in, but same problem.
- MahersMay 28, 2020AspirantActually, things just went from bad to worse. The power down has caused every single device to now show as an "unsecured" connection, preventing internet access altogether. Unbelievable.
- CrimpOnMay 28, 2020Guru - Experienced User
Paperclip reset is all that's left. Sorry.
You also probably cannot access http://<ip of orbi>/debug.htm
Just to double check, can you connect the laptop to the Orbi with an ethernet cable?
(I am astounded that the latest laptops typically do not include an ethernet jack)
