Bjohn1234
Nov 07, 2020Follower
RBR20 Blocking Phone & Ipad Apps
I have just changed my RBR20 setup from AP Mode with BT HH5 to Router Mode with DrayTek Vigor 130 I wanted the extra features Orbi offers in Router Mode. Phone and Ipad Apps like Instagram and Face...
Nov 08, 2020Guru - Experienced User
What mode is the 130 modem working in? bridged or router? IF router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
