imightbewrong
Jan 03, 2024Aspirant
RBR20 Cannot add static IP address - Bad Gateway
I have been running an ORBI RBR20 mesh for several years, and have various devices with static IP addresses. Recently I tried to add another static IP address for home automation purposes, but I ...
imightbewrong
When I said "Bad Gateway" I of course meant "Bad Request"
- CrimpOnJan 03, 2024Guru - Experienced User
Have you turned the router off and back on again?
- imightbewrongJan 03, 2024Aspirant
Thanks for replying. I had not tried that yet as the router was in use all day. I have tried it now. It came back and went into a state where it detected no 'attached devices' and neither of the two satellites - though the network itself worked fine. Hence I could not add any static IP addresses, though the add button did work (i.e. not bring up the HTTP 400 error).
However another button brought up a similar HTTP 500 Internal Server Error page.
I rebooted it all a second time and it came back to a fully working state.
So looks good for now, but I hope these issues aren't a sign of the end of the router life coming.
