DiverAllen216
Jun 18, 2020Tutor
RBR20 Change Network Name (not SSID)
I have two properties each with an Orbi RBR20 mesh wifi network. In my android mobile app, on the Your Products screen, it shows two networks each with the exact same name - RBR20. How can I rename...
DiverAllen216
Jun 19, 2020Tutor
Thanks for the tip. I wound up in this forum by accident. I just reposted in the App forum.
CrimpOn
Jun 19, 2020Guru - Experienced User
If somebody comes up with "how to do this", please come back and update this post. I would have thought this was an "obvious need" that should be almost trivial to accomplish.
