alysha321
Oct 17, 2023Aspirant
RBR20 competing and not working with Spectrum Router
I bought my Orbi RBR20 system from Costco a few years ago, it came with router and 1 satellite. I have had Spectrum since it was Time Warner. I have recently been aware that I have 2 WiFi’s and I was ...
Oct 17, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
- alysha321Oct 17, 2023AspirantOkay option #2 has a lot of IT words that I don’t understand lol. And I’m not sure how to turn the WiFi off any of my equipment The equipment that I have currently is a modem and router from Spectrum connected together and then I have my Orbi Router plugged into my Spectrum router and I also have an Orbi Satellite.
- FURRYe38Oct 17, 2023Guru - Experienced User
Something to contact the ISP about for there help regarding there modem and router equipment.
