DP012
Jul 28, 2019Follower
RBR20 "connected with problems"
Just got Google fiber and I'm streaming (or attempting to) with Amazon firetv and firestick. Using HULU I keep getting "connected with problems" using ORBI. Pandora plays sometimes but drops. Just v...
Jul 28, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
DP012 wrote:Just got Google fiber and I'm streaming (or attempting to) with Amazon firetv and firestick. Using HULU I keep getting "connected with problems" using ORBI. Pandora plays sometimes but drops.
Just very frustrating! Any suggestions?
Thank you
