LSDNana
Dec 16, 2021Aspirant
RBR20 connecting to new wifi
 Changed from ATT Uverse to Xfinity and can't get ORBI RBR20 to connect to the network. Have tried just using reset but device has 'issues connecting'. Shouldn't have to do a new setup, I don't think,...
LSDNana
Orbi app
CrimpOn
Dec 16, 2021Guru - Experienced User
LSDNana wrote:
Orbi app
Oh, dear. I have never set up an Orbi using the app. When you mentioned 'Reset', that was simply pressing the Reset key quickly, correct?
Not a Factory Reset which involves pressing something in the tiny reset hole until the power LED turns amber and begins to flash?
https://www.youtube.com/watch?v=cMw4ePACgc4
