alabama24
Oct 02, 2020Aspirant
RBR20 Connection Issues
I have had an ORBI RBR20 and two sattelites for about a year and a half. At first, it was connected to a DSL wifi router / modem, but in the spring we upgraded to cable. Since that time, it has been ...
alabama24
Nov 02, 2020Aspirant
To follow back up...
Things went well for about a month... then I started having troubles again.
Above I outlined what changes I previously made, but I verified each of these settings and they were as follows:
Enable Beamforming
Enable MU-MIMO.
Enable WMM
Disable 20/40Mhz Coexistence
Disable Fast roaming
Disable IPv6
Preamble mode is currently set to automatic.
One of the things which had been recommend earlier was to disable daisy-chain topology. I have now done so. Fingers crossed.
TURNED OFF DAISY CHAIN TOPOLOGY
- FURRYe38Nov 02, 2020Guru - Experienced User
Let us know how it goes...
alabama24 wrote:To follow back up...
Enable Beamforming
Enable MU-MIMO.
Enable WMMDisable 20/40Mhz Coexistence
Disable IPv6Preamble mode is currently set to automatic.
