alabama24
Oct 02, 2020Aspirant
RBR20 Connection Issues
I have had an ORBI RBR20 and two sattelites for about a year and a half. At first, it was connected to a DSL wifi router / modem, but in the spring we upgraded to cable. Since that time, it has been ...
Nov 02, 2020Guru - Experienced User
Let us know how it goes...
alabama24 wrote:To follow back up...
Things went well for about a month... then I started having troubles again.
Above I outlined what changes I previously made, but I verified each of these settings and they were as follows:
Enable Beamforming
Enable MU-MIMO.
Enable WMMDisable 20/40Mhz Coexistence
Disable Fast roaming
Disable IPv6Preamble mode is currently set to automatic.
One of the things which had been recommend earlier was to disable daisy-chain topology. I have now done so. Fingers crossed.
TURNED OFF DAISY CHAIN TOPOLOGY
alabama24
Nov 04, 2020Aspirant
Unfortunately, we are back to square one. Any other ideas?
- FURRYe38Nov 04, 2020Guru - Experienced User
What mode is your modem working in currently? Router or bridge?
- alabama24Nov 04, 2020AspirantBridge
Can you put the modem back to router mode then configure AP mode on the RBR20?
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure you disable ALL wifi radios on the modem please.
See if it still happens...
