Mkstretch's avatar
Mkstretch
RBR20 Connectivity Question
I have the RBR20 and two satellites. I was wondering if I can plug Ethernet into one satellite and just use wireless with the other satellite. thanks
  • plemans's avatar
    Nov 28, 2022
    Yes you can. You can using both wired and wireless backhauls
