Ciridae
Dec 02, 2019Tutor
RBR20 constant connection issues
I've been through a lot of the previous posts with similar issues and have tried those "fixes" with no success So here's my system: Xfinity internet Arris SB6190 modem Orbi RBR20 router 1,000...
- Dec 16, 2019I’m dropping the switch and time capsule out of the system. I had the time capsule setup correctly so the radios were off but when I used a WiFi scanner it was tagging the router as the Apple time capsule. So I removed it from the system and it cleared up a good bit of the issues. The Xbox is only getting 40 ish mbps download. Once test it jumped to 140mbps but that was only once. It’s enough to stream through it and not get constantly disconnected.
Thanks for all the help and suggestions.
So the recap was first part of the issue was the modem (bad chipset) and second the old time capsule that was being used as a external hard drive was somehow high jacking the orbi (even though the radios were shut off).
CrimpOn
Dec 03, 2019Guru - Experienced User
Is there a pattern to the disconnects?
Just for entertainment value, could you please look at the Orbi web interface, the Advanced Tab, and click on "Connection Status".
The last two lines show the DHCP lease the Orbi received from Xfinity and how much time is remaining on the lease.
- CiridaeDec 03, 2019Tutor
No pattern I can see
lease obtained: 4 days 0 hours 0 minutes
lease expires: 3 days 14 hours 20 minutes
