Ciridae
Dec 02, 2019Tutor
RBR20 constant connection issues
I've been through a lot of the previous posts with similar issues and have tried those "fixes" with no success So here's my system: Xfinity internet Arris SB6190 modem Orbi RBR20 router 1,000...
- Dec 16, 2019I’m dropping the switch and time capsule out of the system. I had the time capsule setup correctly so the radios were off but when I used a WiFi scanner it was tagging the router as the Apple time capsule. So I removed it from the system and it cleared up a good bit of the issues. The Xbox is only getting 40 ish mbps download. Once test it jumped to 140mbps but that was only once. It’s enough to stream through it and not get constantly disconnected.
Thanks for all the help and suggestions.
So the recap was first part of the issue was the modem (bad chipset) and second the old time capsule that was being used as a external hard drive was somehow high jacking the orbi (even though the radios were shut off).
Ciridae
Dec 03, 2019Tutor
2.4ghz is auto and 5ghz is set to 48. I’ve tried all the combinations of 2.4ghz 5ghz and still have the same issues. I have multiple networks around me of varying strength. I’ve adjusted my radios signal strength as well.
Beam forming and WMM are enabled, daisy chain and fast roaming are off. I’ll have to double check IPv6 when I get home. The 20Hz/40Hz button is checked, does deselecting it turn it to 40hz only?
I just factory reset the router Sunday evening.
Dec 03, 2019Guru - Experienced User
Yes.
Sounds like even if you have tried all the troubleshooting suggestions, you may have a faulty or bad RBR.
