Ciridae
Dec 02, 2019Tutor
RBR20 constant connection issues
I've been through a lot of the previous posts with similar issues and have tried those "fixes" with no success So here's my system: Xfinity internet Arris SB6190 modem Orbi RBR20 router 1,000...
- Dec 16, 2019I’m dropping the switch and time capsule out of the system. I had the time capsule setup correctly so the radios were off but when I used a WiFi scanner it was tagging the router as the Apple time capsule. So I removed it from the system and it cleared up a good bit of the issues. The Xbox is only getting 40 ish mbps download. Once test it jumped to 140mbps but that was only once. It’s enough to stream through it and not get constantly disconnected.
Thanks for all the help and suggestions.
So the recap was first part of the issue was the modem (bad chipset) and second the old time capsule that was being used as a external hard drive was somehow high jacking the orbi (even though the radios were shut off).
Ciridae
Dec 10, 2019Tutor
IPv6 is disabled currently on the RBR.
should I run a test with the laptop wired directly to the RBR?
Dec 10, 2019Guru - Experienced User
Yes.
Might try enabling IPv6 on the RBR as well after testing.
- CiridaeDec 11, 2019TutorHere’s the test ran wired to the rbr.
Afterwards I enabled the IPv6.
I won’t have time to check it out until after work today. - FURRYe38Dec 11, 2019Guru - Experienced User
Are you still experiencing connection issues?
You can do this, Might leave the ping plotter program running over night or maybe even during the day if you can and see if it pick up when the connection issues happen.
I won’t have time to check it out until after work today. - CiridaeDec 12, 2019TutorYep, I can’t even get the app to work because the signal keeps dropping.
I think I’m going to run a test.
I’m going to hook the time capsule back up and see if I get all the same connections issues on my old router as I do with the orbi. - CiridaeDec 12, 2019TutorSo I can plug into the rbr directly with my Xbox and get great results. When I go WiFi the orbi will only put it on the 2.4ghz channel and if I wire it through the switch it’s just as bad as the WiFi.
- FURRYe38Dec 12, 2019Guru - Experienced User
So taking the RBR off line and putting your prior router back online, does the system work, wireless and wired?
The Xbox is choosing which frequency to connect too. Orbi only sets up the platform for devices to connect to.
Switch on the RBR or are you using a external switch?
- CiridaeDec 12, 2019TutorSorry I should have specified the switches better.
So when I plug directly into the Ethernet port on the orbi everything is fine. When I connect the switch (GS305) To the Ethernet port and connect through it with the Xbox, it’s just as bad of a connection as the WiFi. I’m using all New cat6 cable.
I haven’t had a chance to swap back to my old router yet. - FURRYe38Dec 12, 2019Guru - Experienced User
Cna you find a different switch to use? Seems like maybe this switch is causing problems for you. Depending on version of switch you have, green ethernet is present on some of these switches which cause problems for Orbi users.
I haven’t had a chance to swap back to my old router yet. - CiridaeDec 14, 2019TutorA little update.
So the new modem helped with some of the initial issues that were annoying. My wife has noticed a huge improvement for her connection during the day while she works. We can actual stream content without it dropping every 10-15 minutes.
The current issues are phone, iPad and Xbox related. I can’t do anything on my phone like stream video or update apps while connected. I constantly have to Either refresh, reconnect or renew the lease for my WiFi on my phone to get it to work. The iPad isn’t as bad.
The Xbox only connects to the 2.4ghz no matter the distance between it and the router. Multiplayer at that point is a no go and even just trying to play a game I constantly lose connection to Xbox live. If I connect through the gs305 switch I get similar results, I even tried making my old router the switch and got the same results. The only way I can use my Xbox is if I plug directly into the orbi. Considering that the WiFi gear is in the office and not the living room is a big hassle.
I haven’t had a chance to test out the old router. - FURRYe38Dec 16, 2019Guru - Experienced User
Caa you find a different switch to use? Seems like maybe this switch is causing problems for you. Depending on version of switch you have, green ethernet is present on some of these switches which cause problems for Orbi users.
- CiridaeDec 16, 2019TutorI’m dropping the switch and time capsule out of the system. I had the time capsule setup correctly so the radios were off but when I used a WiFi scanner it was tagging the router as the Apple time capsule. So I removed it from the system and it cleared up a good bit of the issues. The Xbox is only getting 40 ish mbps download. Once test it jumped to 140mbps but that was only once. It’s enough to stream through it and not get constantly disconnected.
So the recap was first part of the issue was the modem (bad chipset) and second the old time capsule that was being used as a external hard drive was somehow high jacking the orbi (even though the radios were shut off). - FURRYe38Dec 16, 2019Guru - Experienced User
Awesome troubleshooting. Glad you got it working. Thanks for letting us know. Please mark your thread and solved so others will know.
Enjoy. :smileywink:
