Ciridae
Dec 02, 2019Tutor
RBR20 constant connection issues
I've been through a lot of the previous posts with similar issues and have tried those "fixes" with no success So here's my system: Xfinity internet Arris SB6190 modem Orbi RBR20 router 1,000...
- Dec 16, 2019I’m dropping the switch and time capsule out of the system. I had the time capsule setup correctly so the radios were off but when I used a WiFi scanner it was tagging the router as the Apple time capsule. So I removed it from the system and it cleared up a good bit of the issues. The Xbox is only getting 40 ish mbps download. Once test it jumped to 140mbps but that was only once. It’s enough to stream through it and not get constantly disconnected.
Thanks for all the help and suggestions.
So the recap was first part of the issue was the modem (bad chipset) and second the old time capsule that was being used as a external hard drive was somehow high jacking the orbi (even though the radios were shut off).
Dec 16, 2019Guru - Experienced User
Caa you find a different switch to use? Seems like maybe this switch is causing problems for you. Depending on version of switch you have, green ethernet is present on some of these switches which cause problems for Orbi users.
Ciridae
Dec 16, 2019Tutor
- FURRYe38Dec 16, 2019Guru - Experienced User
Awesome troubleshooting. Glad you got it working. Thanks for letting us know. Please mark your thread and solved so others will know.
Enjoy. :smileywink:
