zhoux
Jul 15, 2020Aspirant
RBR20 constant connection issues
Since the update of the mobile phone orbi software, the network disconnection phenomenon often occurs, and it is necessary to turn off the instrument and reconnect the program almost every day. I hop...
Jul 15, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
zhoux
cox internet
Orbi RBR20 router
no satelittle
several other WiFi networks
firmware Version V2.5.1.16
Router and network host next to each other
2500 sq ft home
Mobile computers and TVs use 5GHz
Not sure where to disable the option, and how to view
- FURRYe38Jul 15, 2020Guru - Experienced User
Use a PC or laptop and web browser to make any changes to the RBR.
- zhouxJul 15, 2020Aspirant
I'm sorry I don't understand some of the information you asked me to provide. I have a photo here including some information on the Internet
Can you list what settings I need to make?
thank you very much- FURRYe38Jul 15, 2020Guru - Experienced User
What is the model# of the ISP modem the RBR is connected too.
You'll need a PC or laptop connected to the RBRs web pagr to make any changes. The Orbi app doesn't provide this kind of change feature.
