Izfair
Apr 04, 2020Follower
Rbr20 constant purple led no connection
Hi I have an ADSL internet connection and purchased an Rbr20 + 1satellite a few months ago because I couldn't get the WiFi to reach all parts of our house (3floors). Soon enough the problems started:...
Apr 04, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Izfair wrote:
Hi
I have an ADSL internet connection and purchased an Rbr20 + 1satellite a few months ago because I couldn't get the WiFi to reach all parts of our house (3floors). Soon enough the problems started: suddenly we'd get the purple led flashing on the router and lost the connection. Things seem to have got worse with the new software download. Sometimes the connection stays on for hours, and then suddenly we can't get it to work despite all the reloads we do. We work from home so we need to get this sorted ASAP, this is not sustainable at all.
Thanks
Retired_Member
Apr 04, 2020
FURRYe38 wrote:What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Izfair wrote:
Hi
Thanks
no copy paste...please
