Retired_Member
Feb 04, 2019RBR20 constantly disconnects
I’ve had our Orbi since August of 2018. In the last month our satellites constantly lose connection. They worked fine before. We have to constantly reset the router. The firmware is up to date.
- Feb 07, 2019
Any progress on this?
Feb 05, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
