JC357C
Mar 29, 2019Follower
RBR20 Default Setting after 24-48 hrs without any power failure
I currently have a RBR20 router with a firmware Version of 2.2.1.210. Since I returned from a deploymnet the router was working properly for about 2 weeks. The last week the router keeps defaulting b...
ekhalil
Mar 29, 2019Master
JC357C wrote:
......... The last week the router keeps defaulting back to default setting without any power failure. I loose all settings and I have to do a new set-up once a day.
The router should not reset itself to default settings.
Likely, you have a poor password and someone is just playing with you! Please make sure to have a stronger admin password.
If I check my Logs, I see hundreds of remote login trials daily.
