JC357C
Mar 29, 2019Follower
RBR20 Default Setting after 24-48 hrs without any power failure
I currently have a RBR20 router with a firmware Version of 2.2.1.210. Since I returned from a deploymnet the router was working properly for about 2 weeks. The last week the router keeps defaulting b...
Mar 30, 2019Guru - Experienced User
Let us now if the suggestions help any.
JC357C wrote:
I currently have a RBR20 router with a firmware Version of 2.2.1.210. Since I returned from a deploymnet the router was working properly for about 2 weeks. The last week the router keeps defaulting back to default setting without any power failure. I loose all settings and I have to do a new set-up once a day.
I have done the following steps and I have not been able to fix the problem.
1. New Set-up
2. Factory reset
3. Press the reset for 30/30/30
4. Try to update the firmware, but is telling me is up to date.
Thank you in advance for your help.
Joff
