guycarmin
Nov 14, 2019Aspirant
RBR20 devices connecting to 2.4 GHz
Hi, I have the Orbi RBR20. I've connected it and configure - now I see that all of my devices (Window Laptop, Linux Laptop and several Galaxies (S7-->S8+) are all connecting initially to the 5Gh...
guycarmin
Nov 19, 2019Aspirant
Hi - Thanks for replying so fast ;-)
Firmware V2.3.5.26
The hous is about 1,800 SQ/Fit on 3 flors.
The Router and (currentally) one Satellite which are phisically connected with CAT7 LAN, and are one floor up and about 10 fit aside.
I have one neibghour 2.4GH wifi but from wifi scanning it's not interfiring (from channles and strength perspective.
I've already enabled Beamforming, MIMO and WMM.
just disabling Daisy Chain, as I've already disabled all the rest.
The point is that all of my devices (2 laprtops, several Galaxy phones and 2 tablates) all connecting to 2.4Ghz.when connecting to the network - they are connecting to the 5Ghz, but then they (ALL) migrationg to the 2.4Ghz. It's happans even if I'm 2ft from the router. Also - when I'm on the second flor I see another wifi with the same SSID with no password - and when I try to manually connect to it I'm getting the 5Ghz (but then the device goes back to the 2.4).
Thanks,
Guy
Nov 20, 2019Guru - Experienced User
"The Router and (currentally) one Satellite which are phisically connected with CAT7 LAN, and are one floor up and about 10 fit aside" 10 feet? If so, then this is too close between the RBR and RBS. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- guycarminNov 20, 2019Aspirant
They are connected via LAN (1/10G ethernet cable).
It's a blok and concrete house.
the RBR is on ground floor where the RBS is on the secound floor. this is the elevation distances while the vertical distance would be about 10~15ft. so the total is about 30ft ?I would say.
Thanks,
- FURRYe38Nov 20, 2019Guru - Experienced User
OK, block and concrete will be a a factor and maybe problematic as this would be effecting the 5Ghz signal which maybe one reason why your devices are reverting to 2.4Ghz...
I suspected that as well - so I tested it when the RBR is just 1ft away from me without any obstacles...(I've just took him out and put him on the table near me...)
