dapn
Jan 07, 2022Aspirant
RBR20 dhcp renew goes wrong
Hi,
I have this issue, that the Orbi stops internet routing during the renew process. For no real reason. I have set up a win10 pc, wireshark to investigate the ISP, and eventthough they run very short leasetimes, it doesn't fail.
But the orbi, is kind of useless at this. It looks as if the router simply restarts its ethernet driver on renew. Thus there is a 3-5 seconds drop of internet, during the renew even though i get the exact same IP. Even if you press the renew button on the advanced tap.
This would probably not be a problem unless you have a very short leasetime, then it gets quite anoying.
Its quite easy to check. you just from your pc. start a cmd ping google.com -t
and then go to the connection status Connection Status
And press the renew button. This should not interfere with the continous ping. the router should beable to maintain a stable connection during this process.
And I use the latest firmware, if any one can recomend a better firmware, please do so.
Regards
Daniel
