williefriends's avatar
Dec 14, 2020
RBR20 disconnect when DHCP allocates IP address
Internet connection on wifi drops frequently. The timing always coincides with a message in the log - [DHCP IP: 192.168.1.3] to MAC address xxxxx
I have tried every single way in this forum, i.e. updated firmware, tick off Daisy-chain, etc, but the problem still continues. I also allocate each device with a static ip address but Orbi just keeps doing this DHCP thing every 10-15 mins or so.
Does anyone have the same problem and got it fixed? Thanks!!
  • FURRYe38's avatar
    What is the device at .1.3?
  • CrimpOn's avatar
    CrimpOn
    Are these "static IP's" (a) set on the devices themselves in their network setup, or (b) in the Orbi LAN Setup page?
