gear-fan
Jan 09, 2022Aspirant
RBR20 does not show all attached devices
Hi, I've had this setup (on base and 2 satellites) working well for over a year now. Satellites are connected to the base via ethernet and firmware is up to date (V2.7.3.22) on all three units. How...
CrimpOn
Jan 10, 2022Guru - Experienced User
gear-fan wrote:
Hi, I've had this setup (on base and 2 satellites) working well for over a year now. Satellites are connected to the base via ethernet and firmware is up to date (V2.7.3.22) on all three units. However, both the app and the web portal are not showing all the connected devices. I have at least three devices that are set to static IP, but only one is showing up. The other two are working fine though. Now I'm not sure if there are other devices (DHCP) that are also missing. Yesterday it was showing me that 41 devices were connected, today it is showing only 34.
Are these IP's set (a) on the actual device, or (b) as an entry in the Orbi LAN Setup Address Reservation table?
gear-fan
Jan 16, 2022Aspirant
They are set on the device, outside the DHCP address pool on the Orbi. BTW, the Fing app finds all the devices correctly.
