Anzy
Jan 06, 2020Aspirant
RBR20 Doesn't factory reset and lost wifi capabilities
Hello, Since we moved all our satelites and the router around my house I went ahead and tried to setup a new system. It had problems finding the newly named wifi and couldn't proceed with the set...
Anzy
As i have mentioned before what happens it it prompts me to the mobile app and doesn't let me in the router settings through wired connection.
CrimpOn
Jan 06, 2020Guru - Experienced User
That is where I am confused. Something comes up on the web browser from http://192.168.1.1 instead of the Orbi home page?
- CrimpOnJan 06, 2020Guru - Experienced User
Can you capture a screen shot of this and post it?
- AnzyJan 06, 2020Aspirant
Okay I apologize as there was a skip button on the bottom that i didn't see, however that doesn't eliminate my problems with wifi capabilities of the router.
Update: the wifi has established after unusually long time, but now keeps dropping to what i posted in my last reply. Usually takes 1 minute to crash down and 1 minute again to re-establish
