areynoso
Oct 12, 2019Guide
RBR20 doesn't work
Buy an RBR20 and 2 satellites 3 months ago, I have weeks that disconnects from the internet without explanation, I have read in the forum that many have this problem, say some solutions that works fo...
- Oct 14, 2019
did you try the 2nd set of suggestions? have you tried doing the tftp procedure on it? it forces the firmware to it. This fixes the majority of flashing power problems.
If that doesn't work the only other utility is nmrpflash.
https://github.com/jclehner/nmrpflash
areynoso
Oct 14, 2019Guide
I understand the first point, but it is not running in router mode and I understand what you say about armed concrete, but my problem is not signal, is that the router orbi has no internet, does not show the wifi network and also local by means of a LAN cable , does not allow me to reset it from factory, the light always flashes and I can not do anything else.
Oct 14, 2019Guru - Experienced User
