areynoso
Oct 12, 2019Guide
RBR20 doesn't work
Buy an RBR20 and 2 satellites 3 months ago, I have weeks that disconnects from the internet without explanation, I have read in the forum that many have this problem, say some solutions that works fo...
- Oct 14, 2019
did you try the 2nd set of suggestions? have you tried doing the tftp procedure on it? it forces the firmware to it. This fixes the majority of flashing power problems.
If that doesn't work the only other utility is nmrpflash.
https://github.com/jclehner/nmrpflash
areynoso
Oct 14, 2019Guide
I was able to initialize the router again, then now the problem starts and that is that the connection is lost from time to time, the router was disconnected from the internet.
