areynoso's avatar
Oct 12, 2019
RBR20 doesn't work
Buy an RBR20 and 2 satellites 3 months ago, I have weeks that disconnects from the internet without explanation, I have read in the forum that many have this problem, say some solutions that works fo...
  • plemans's avatar
    Oct 14, 2019
    did you try the 2nd set of suggestions? have you tried doing the tftp procedure on it? it forces the firmware to it. This fixes the majority of flashing power problems.
    If that doesn't work the only other utility is nmrpflash.
    https://github.com/jclehner/nmrpflash
