WeAreDevo
Dec 02, 2019Aspirant
rbr20 dropping devices
About 4-6 weeks ago started having issues with wifi devices -- dropping / disconnecting from wifi, then reconnecting. I replaced my hub with a switch for the wired devices (playstation, tv cable ...
CrimpOn
Dec 02, 2019Guru - Experienced User
A good place to start is to describe:
- Exactly which version of firmware is on the Orbi router and satellites.
New firmware was released 4-6 weeks ago that appears to have caused problems for many users and has actually been "withdrawn". If your Orbi is on the 2.5.0.38 or 2.5.0.40 firmware, a lot of people advise to download the 2.3.5.30 firmware and install it manually. - Exactly which brand/model of modem is the Orbi attached to.
- WeAreDevoDec 02, 2019Aspirant
Netgear Orbi rbr20
firmware V2.3.5.26
modem: technicolor TC4300.E
- FURRYe38Dec 02, 2019Guru - Experienced User
Your FW should be ok. Your system does not support v38 or v40.
Your modem is only a modem which is good. Its a modem only which is recommended.
Let us know about the other suggestions. Please give feedback. Hopefully something stands out.
WeAreDevo wrote:Netgear Orbi rbr20
firmware V2.3.5.26
- WeAreDevoDec 04, 2019Aspirant
Still having issues...
Have tried all of the above suggestions...nothing working.
Spent 45 minutes on the phone with netgear support...no success...
Manually updated router to V2.3.5.36 (hot fix).
Router firmware updated, but when I tried to upload the firmware update for the satellite it kept giving me a file error message. I tried with my laptop hardwire to the satellite as well as wireless....
So I wanted to get some more data...so, I opened orbilogin.net on my laptop (Ubuntu). and watched the "Internet Status" About every 5-10 minutes or so it changes from Good, to no internet for a few seconds, then back to "good".
Watching the "wireless connections available" on devices, the router just "disappears" for a minute or so about every 5-10 minutes or so, then reappears. But sitting right in front of the router, the lights do not change on it.....And sitting right in front of the modem when this happens, none of those lights change either...
I need to buy a couple more Mesh Network Systems for some income properties....do not think I will be buying Netgear, as this issue is frustrating the heck out of me, and the phone support did not solve the problem....Probably buy the Google system? Maybe D-Link?
- Retired_MemberDec 02, 2019
Looks like your modem (gateway) is a modem/router combo.
FYI....
What is a Gateway? Put simply, a gateway is a device that combines the functions of a modem and a router. A modem is a device that connects to your cable or phone lines and translates the data or information from the Internet to your computer or connected device.
To make this work, you'll have to configure one (Orbi outer or the other modem) as a access point or bridge.
You might check with your IP and ask if you can run a single regular type modem. That way the Orbi will behave.
My Modem is just a modem, not a modem/router combo.
