WeAreDevo
Dec 02, 2019Aspirant
rbr20 dropping devices
About 4-6 weeks ago started having issues with wifi devices -- dropping / disconnecting from wifi, then reconnecting. I replaced my hub with a switch for the wired devices (playstation, tv cable ...
Dec 02, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
WeAreDevo wrote:About 4-6 weeks ago started having issues with wifi devices -- dropping / disconnecting from wifi, then reconnecting.
I replaced my hub with a switch for the wired devices (playstation, tv cable box, phone box).
Then through my Internet servcie provider did a full diagnostic of modem and cable lines -- all good, and all up to date.
Then, reset router, returned to factory defaults, ensured firmware was up to date, reset to factory defaults again...set channels instead of auto (used the netgear wifi analytics to choose channels)....
wifi signal continues to go down / drop for a minute or two, then reconnect. The light on top of the Orbi does not change when this happens...
Any suggestions?
- Retired_MemberDec 02, 2019
more copy paste
- WeAreDevoDec 02, 2019Aspirant
Satelite is about 20 feet from router.
Never have an issue with satelitte not being connected.
Have tried various different chanels. Used the wifi analyzer app to select chanels.
Also tried the following:
"Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s)."Still not working.
