Jpatullo
Nov 30, 2022Aspirant
RBR20 dropping internet and satellites losing connectivity
I have this same problem (wifi dropping, satellites losing connection to the router). My router is running the latest firmware V2.7.4.24, I have two satellites. This system has been rock solid for...
Dec 01, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
️What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Traffic Meter.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Jpatullo
Dec 08, 2022Aspirant
Thanks for the feedback. I was able to rectify the situation by a hard reset of the modem, router, satellites, then resynching the satellites.
