robert1308
Aug 27, 2020Aspirant
RBR20 dropping internet connection regularly
Since a couple days, as far as I remember after the upgrade of firmware, the internet connection drops regularly while the WIFI is still connected. I checked the WAN connection status, it is disconne...
Mstrbig
Aug 27, 2020Master
robert1308 wrote:Since a couple days, as far as I remember after the upgrade of firmware, the internet connection drops regularly while the WIFI is still connected. I checked the WAN connection status, it is disconnected. Anything I can do?
There have been several posts about updating firmware and having issues.
What firmware is installed your Orbi RBR20 have on it? The official release is 2.5.1.16
robert1308
I have the latest firmware version 2.5.1.16
I've gone through several similar posts, none of them provides a reliable solution
- FURRYe38Aug 27, 2020Guru - Experienced User
Do you have Armor or Circle enabled?
robert1308 wrote:I have the latest firmware version 2.5.1.16
- robert1308Aug 27, 2020Aspirant
I'm located in the US.
I tried to connect dirrectly to the internet with my computer the whole day, and did not experience any drop.
I did the factory reset, is there any hard reset we can do?
If you did a factory reset and setup from scratch on the RBR, this is a hard reset.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
