malibuskier
Mar 19, 2021Follower
RBR20 dropping internet
Orbi is dropping internet connections (both wired and wireless) about every 2 hours since Monday. A restart fixes the issue but this is a pain. I did a factory reset yesterday but that hasn't helped. ...
BillYoung
Mar 19, 2021Luminary
Your issues sound like the ones I had with my RBR50 which is on 2.7.2.104. To fix my connectivity issues, I had to do two things.
1. Reboot both your Orbi and your modem for 1 minute. Restart the modem first, then the Orbi router, then any satellites you may have.
2. Change your NTP settings from the Netgear NTP server to time.nist.gov.
Doing both of these fixed my connectivity issues.
I hope that they will fix yours.
