mikemcgl68
Oct 01, 2021Aspirant
RBR20 dropping internet
Yesterday, my wifi started dropping. I have had the RBR20 configured as an Access Point behind my Verizon Fios router, on which I turned off the wifi. It had been working seamlessly. I had set up ...
Oct 01, 2021Guru - Experienced User
So turning OFF the Orbi system you still see problems with the ISPs modem and wifi?
mikemcgl68
I did not try that - I will when I get home tonight. I will have to turn the wifi back on from the Verizon router.
I had also seen something in another post about some bug in a Traffic Meter, which I will also attempt.
