campbell11
Oct 17, 2022Aspirant
RBR20 drops internet
I have the RBR20 and 2 x RBS20, bought in 2019 and worked perfectly up until a few months ago. Firmware is up to date 2.7.4.24. The last couple of months the RBR20 just drops out of internet all th...
- Oct 17, 2022
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Oct 17, 2022Guru - Experienced User
- campbell11Nov 01, 2022Aspirant
Thanks heaps, sorry for late reply.
I did all the power off in the order you said and since then it has been working fine. Very weird.
thanks again
- FURRYe38Nov 02, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
