MartienR
Sep 27, 2020Aspirant
RBR20 Ehternet port doesnt't work after firmware upgrade
I installed the newest firmware to my RBR20 (v2.5.1.16). After the reboot of the system, the ethernet port on the router doesn't work anymore. I have attached a netgear gs105 switch attachted to it. ...
- Oct 05, 2020
Issue solved. When I connected a device directly (without NG gs105 switch), it did work. Problem was the switch. Bought a new one (TPLink) and everything works again.
MartienR
Oct 05, 2020Aspirant
Oct 05, 2020Guru - Experienced User
Interesting, what rev version is the GS-105 switch? Was the switch just bad?
Glad you got it resolved.
